if the car will not crank, but the radio and everything else works what would be the problem on a plymouth send reply to kjv34@msn.com title cartalk
Neutral safety switch, clutch switch, weak battery, corrosion at cables, bad starter. Got any more information for us?
thanks for the reply I don’y have any more info checked all the fluids there was no corrosin on the batteries the battery is about 2 weeks old so that’s new, my cousin thinks it could have been that when she has it checked the mechanic jamed the key into the starter and couldn’t get the key out my cousin got the key out with no problem when she got home could that cause the problem thanks again sorry I couldn’t give you more info
