Plymouth Breeze won't stay running
'96 Plymouth Breeze runs fine for about 10-15 minutes then shuts down and won’t start again. If let sit for a while (10-15 min.), it will start again but then shuts down again after about 10-15 minutes. Battery, coil pack and timing belt have all been replaced. Any ideas?
A faulty crankshaft position sensor can cause this problem. The crankshaft position sensor is threaded into the block, and is located above the oil filter.
I’ll have that checked - thanks for the help!
