Pcm
i have a 2000 dodge caravan .itook it to get inspected and it failed code 610 .i had the computer reset but code is still there. how can i fix this .
what ? 610?(non existant)
how did you get the code?
bye!
i have freind put it on his machine that tells codes and resets computer
the excat error message reads p0601 internal control moduel memory check sum erreor
K, BADBOY!
thats not a real code. PO300,EXAMPLE. I have the same tool my cost 8000.00,you need to get it read properly.
then POST back.
OUT!
now your cookin.
the rest of the board will CHIME in.
GOOD LUCK!
thank u
That means the module is toast and needs to be replaced as I recall.
The computer has detected an error in it’s internal memory. First, I would try disconnecting the battery for 30 minutes and see if the problem clears. I doubt that it will work but it is worth a try.
Talk to a dealer and see if the memory can be re-loaded (reflashed) to fix the problem.
The next step would be new computer.
