Not the clock spring
The cruise and horn quit working. Told to change the cloclk spring. All wires in place and fuse checked.
This is the third thread you’ve started on the same subject. Others are answering in your other threads. Spreading the problem out across multiple threads annoys the people answering, and confuses the answers anyway which means you won’t get the help you need. I’d suggest reading the other two threads you started.
