The seats in my xterra will not adjust front or back, there does not seem to appear to be anything on the tracks and both adjustment levers appear to be working properly. They both only move about an inch. Any suggestions?? Thanks, Kevin
You’ll have to check with a tester to ensure you ARE getting 12V to the seat adjusting motor and to the switch.
There MAY be a broken wire from the adjustment movements.
Whoops! Power or not?
If not, the wire that connects between the lever and the lock my be broken or stretched.
