New Intermediate Steering Shaft U Joint Won't Articulate, Yolks Mechanically Binding
2005 Camry,
I’m trying to replace my intermediate steering shaft. Looking at the new part, I’m noticing that the top u-joint will not fully articulate. The u joint yolk is binding with the other yolk, not allowing full articulation to occur. Kind of seems like a big thing to miss during the assembly process. I’m wondering if this part is supposed to be like this?
In this video you can see the bottom u-joint that attaches to the rack and pinion fully articulates no problem, but the top one that connects to the steering wheel does not.
Thank you!
I was also wondering, the telescoping shaft, does telescoping only occur when you raise and lower the steering wheel? Does telescoping occur when going over bumps? I see some clear grease where the two shafts meeting (likely silicone grease). But I would imagine it doesn’t telescope much?
The upper U-joint is what allows the steering wheel to tilt up and down.
Thanks, so if you get into an accident as well.
Would you happen to know if my top u joint is supposed to fully articulate? Kind of odd something like this would have been missed. But it barley articulates at all in one direction, because the two yolks hit each other, allowing for little movement.
I’m outta here but isn’t the top joint for the tilt function? Up or down, not left and right also.
But why are you disassembling the steering shaft? In almost two million miles, I’ve never had a shaft wear out.
Please stop overthinking this . . . and anything else car-related, as well . . . and just install the darn part already
If you have yolks in the part it is going to be difficult to clean. Yokes, however, are easier to deal with mechanically.
The intermediate shaft is fully compressed and interfering with the joint. Pull the inner shaft out a few inches. You will need to lengthen the shaft during installation, it won’t reach if fully compressed.
Yea I’m just trying to figure out if the part is defective or not. There’s lots of slop in my steering wheel without turning the tires. And a knocking sound when going back and forth a few degrees. Was in a newer rental car a few weeks ago, and it was dead silent when rotating the steering wheel back and forth a few degrees. I think the u joints might be worn out on my original one. See lots of grease along it that leaked out of the original one.
With the shaft fully extended, the yokes are still interfering with each other in the top u joint. Kind of seems like a hard thing to be missed and screwed up on assembly. Making me wonder if this part is supposed to be like this.
Looks like the SKP one, the top u joint doesn’t have this issue, but the bottom does.
Ultra Power replacement part doesn’t appear to have this issue for either u joint.
With the telescoping functionality only being a function for accidents are adjusting the steering wheel height, seems to be an infrequently used function, and not worth regreasing, ever.
The maximum useful angle of a U-joint (or cardan joint) is 45 degrees. In-use as a steering shaft you will never see angles as large as 45 degrees.
Prove it to yourself. Look at the shaft in the car now. Turn the wheel 360 degrees as a test at each angle of tilt. Measure the angle of the joints at the greatest angle. The angle to the steering rack is likely the largest angle. I’ll bet it doesn’t come close to 45 degrees at any point.
The shaft is fine as designed and built.
That said, have you tested the slop in the shaft that is in your car now? Are the U-joints loose? Is the collapsible portion sloppy?
Thanks for the help. I finally got under my car to try and confirm the design. The one installed in my car appears to be the kind where the u joint yokes do not interfere with each other, on either end.
No different than the intermediate shafts in your pictures, the joints just need to be straightened out to align with the column shaft and rack & pinion. Those were folded over during packaging.
I think the one I have, the yokes interfere with each other on the u joint that is supposed to connect to the steering wheel portion.
The one in my car (I believe the original) has a design where the yokes do not interfere with each other on either end.
The SKP part appears to be a design where the end that connects to the steering wheel, the yokes interfere while the Ultra Power one does not.
It seems like two different designs to me, but there not? Not sure I understand.
I’m not able to unfold the yokes on the top u joint so that they don’t interfere with each other, to match what is in my car.
As I understand what Nevada is saying above, you first have to stretch that part to make it long enough to cover the space provided. In other words it comes compressed for ease of shipping. Now you have to somehow un-compress it to the correct length. Have you done that?
Insert a long screwdriver into the shaft opening for added leverage to straighten the joint. When the joint is straight, what seems to be interfering with movement?
The OP’s ability to do anything without a 30 day discussion on it.
@YoshiMoshi3
With all due respect . . .
WHAT IS YOUR PROBLEM . . . ?!
You have been told repeatedly that you received the correct part
You have been told repeatedly to just install the part
And you are not doing so
And yes . . . the capital letters were no mistake
It was indeed meant to come across as yelling
Another overthinking everything Tread… I sure hope it doesn’t take that long to figure out what toilet paper to buy… gezzz
There is paying attention to detail and being cautious, and then there is just flat out going overboard…
And the flag police wonder why the discussions may get a little off topic once in a while. Is yelling though violence? And is that a form of disrespect that should be flagged?
If I get flagged, so be it
I honestly think it was warranted in this case
I have a preferred brand
I stock up when it’s on sale at Costco
easy peasy :smile_cat:
no overthinking
