Was at Auto Zone today. They had this HUGH sign out front about a GREAT Fuel Saving device that’s guaranteed to save you gas. As I went inside they had a display with this simple Fuel Saving device…
A Tire Pressure gauge.
At last, one that can work.
But did they tell you how/where to use it and what it’s for?
I’m not sure half the people on the road know how or even where to check their tire pressure.
I thought it was pretty cleaver. I chuckled when I saw what it was.
True…but it’s still far better then any Fuel Saving Device that keeps getting posted here…aka “Water for Gas”.
I have one taped to each plug and I now get 600% more fuel economy.
No, seriously though, I have one on a magnet on the inside of my gas door. I check the tires at each fuel up. I did test the gauge and it was 2 psi off, but I just have that written on a piece of tape on the back of the gauge, as long as it reads constant I can work with it.
Take that magnet and tape it to the fuel line (or is that the air cleaner) and you will get that 600% improvements with all those atoms lined up. Hey, put one on the air cleaner to and that would make it 36,000,000% improvement.
It is nice to see a company doing it’s part in promoting actual working devices like tire gauges.
Finally a serious post. too bad the gullible don’t apply this sort of logic to the other posts!
Remember When air was free
Great post and a pretty ingenious way of getting a point across!
Wonder how many of the water into gas crowd even owns or has considered financing a tire pressure gauge.
It is also a great lifesaver. Tires are critical component.
I know how to make cabbage into gas
A very good point. Wonder how many tires let go every year due to underinflation rubbing the sidewalls out?
It’s air for gas!
