I have a 95 jeep cheeroke and have lost all power to my radio, heater, wipers and turn signals, i have checked all fuses and replace a relay i thought may have been bad, i have yet to xfind any inline fuses that may causethe issue, please help
If you don’t have a test light probe to check for power I suggest you purchase one. Use it to see if the fuses in the dash are getting voltage to them with the ignition switch on. If some of them aren’t getting power then verify all the fuses under the hood are okay. If they are then the most likely suspect for the problem is the ACC contacts of the ignition switch.
