No power
i have no power to my radio, wipers, ac controls and windows. All lights work and dash work where instruments are. This problem has happen before about 4 times in 2 years but has cleared up. All fuses are good suspect wiring or computer glich can you help me?
It sounds like it could be a bad ground for the interment panel. I would guess the four way flashers also go out.
problem is locating all grounds i have no print also the abs light is on and it appears to be working fine.cruse control does not work either.where do i get prints
