I have a 95 Jeep Cherokee that has a strange electrical problem. When I first turn the car on after it has been sitting for several hours, the following accessories do not work:
- Air conditioner/Ventilation
- Wipers
- Cigarette lighter
There are two really odd things going on here: The first is that the radio will not work if any of the above three things are turned on, but it WILL work if they are all turned off. For example, with the wipers and AC off, and cell charger unplugged from the lighter, the radio will turn on. As soon as I plug the charger in, or turn on the wipers or AC, the radio goes off. None of these accessories actually turn on, but simply being putting them in the “on” position kills the radio until they are switched off.
The second weird thing is that after a few minutes of driving, everything will return to working as normal - radio, AC, lighter, etc. They continue to work until the next time the car has been sitting for several hours, at which point the same problem repeats.
FYI, I recently replaced the alternator to address an unrelated issue, but it did not make a difference with this one.
I searched the car talk forums for similar issues, but did not have any luck - while it does look like there are some other Chrysler vehicles that have electrical problems, I couldn’t find anything dealing with an intermittent problem. Please let me know if you need any more info, and I appreciate any suggestions to help me troubleshoot this!
