I have a 1998 Olds Sihlouette, and I am hearing a noise when I turn the wheels right or left, staring from a stop. It sounds like a spring or something thumping. Also, I am not getting any heat , either. Just had 8 million hoses replaced on the heater hose assembly, but the climate control just blows cold air.
could be wore out cv joint check and see if the rubber boots are leaking. May need to bleed air out of the sysstem to get the heat to work.
This post came up first on Dec 26 and was answered. If this was bumped up why aren’t the replies with it?
