My power seats
Y power seats no longer move
U broke it.
You may want to check any connectors involved. It might also be a fuse, but if it is, you should consider that fuses don’t wear out, they blow out when too much current runs through them, so a blown fuse COULD mean you need a new motor.
Ur plug-in connectors under the seats that connect the seat motors to the switches may be loose. Vacuuming under the seats can do this sometimes. Have you checked?
