I have a 1993 eclipse and everytime i turn left it boggs down and dies. I changed the fuel pump, fuel filter, and also cleaned the injectors. I have no idea what is wrong. If anyone knows please write back! Thanks…
Check motor mounts and battery cable.
Check the motor mounts for excessive wear. They could be worn enough that when the car turns left, the engine moves enough to pull on the battery cables strongly enough that the battery cables momentarily break contact with the battery posts, or where the cable attaches to the motor or fender, or power strip.
[I know it’s the same thing JES said. I just used more words.]
