A year ago my 1998 chevy camaro 6 cyl eng. randomly did not start.  Then came back to it 15 min later and it started right up and did not give me another problem.
3 months ago it did the same thing, but then would go a week at least with no more trouble sometimes longer sometimes more frequent.
within this past month it has become very frequent and I have had to push start it with the clutch a few times to get to work. It starts right up when I pop the clutch every time. Now the car will not start with the key no matter what.
Some more details on what it does now - When I first get in it after it has sat a little while you can hear the starter solenoid click the first three times or so when I turn the key. After that you do not hear the solenoid click anymore, but the relay up under the hood clicks every time with the key. (for kicks I even swapped the starter relay and the ignition relay with no change)
The battery is fairly new, but I load checked it anyway and it is perfect, plus I tried another good battery and jumper cables from a battery in a running car so that’s not the problem. I have cleaned all corrosion off terminals and the ground to the engine and to the car.
I checked the resistance of the little piece on each of two ignition keys and they check fine.
I have checked the clutch switch down by the pedal multiple ways. checked resistance of the switch, voltage when the key is on and jumpering the plug with a paper clip.
when I push start the car and have it running I can turn the key with the clutch out nothing happens, but if I push the clutch in the starter will engage (grind) every time (I didnt do this a lot). this tells me that the clutch switch is working and the started is working right?
I did switch the starter out with another used unit and it did the same thing.
I unhooked the alternator on the off chance a short in that was drawing too much juice and not giving enough to the starter (I know I am really reaching here).
I am completely stumped - no idea what so ever. Any Help would be greatly appreciated!
