The low beams cut off after 4 to 5 minutes,I hear a click when it happens. All the other lights continue to work. The high beam turns on when I pull the lever back and hold it on. Then after a few minutes the low beams turn back on with a click.The turn signal auto off after turn is broken.
The low-beam relay may be weak. Replace it and find out if that takes care of the problem.
I wonder if the click you are hearing is due to a circuit breaker turning off. If it is there may be a little too much current being drawn on the circuit or the breaker may be bad.
