Locking system on '87 BMW 325i
I recently purchased and had installed a new battery. Prior to that I could lock both doors and the trunk from the trunk with one key twist. Since the battery change I must lock each door and the trunk separately. Can I fix this or do I need to go to a BMW dealer?
BMW is listed here http://www.aa1car.com/library/battery_disconnect_problems.htm that can have problems with the modules when the battery is disconnected. The vehicle may have to be taken to the dealer so BCM can be reprogramed with a scanner.
