Lexus dealer: $1,000+ for 60k transmission maintenance. 2023 RX350h
Is that the display value when hot? The owner’s manual shows 41psi cold, this would read 45 - 46 psi when the tires are hot.
After driving 100 miles.
I should keep records of vehicle outside air temperature and TPMS tire pressures.
Heading west on an interstate, the left tires in sun became 1psi higher than the right tires in shadow.
41…40
41…40
What can you do about that? Turn the car around and drive backwards?
Mount white sidewall tires on the south side!
