05 nissan frontier knocking noise when driving from right front wheel ,dont think its brake related ,still drives smooth
Could be something in the wheel cover or a loose wheel cover or a CV joint or bearing …
thanks for the help joseph, no wheel caps .I am afraid its a cv joint or bearing ,is that expensive ?? Maybe covered by warranty 32k???
Yes, it should be covered by eth warranty. And I agree that it’s a likely CV joint. If a boot gets torn their lifespan is short, and they do typically make a knocking sound. The sound is usually when turning, 'cause that’s when the joint is articulated.
