Kia Window Regulator
I have an 2002 Kia Spectra. The Front Passenger side power window regulator broke. The up cable broke off its plastic mount and it caused the cable to kink. The motor is fine. Can I purchase a manual regulator and use it with my motor or can I swap the plastic mount piece with the one from the rear passenger door? I’m looking for a cheap fix that will last a few months.
You have to replace the motor/regulator as a unit.
The cheapest source is a used motor/regulator from a local auto recycler.
