I’m trying to replace a low beam light in the headlight assembly, I only see 1 bolt that goes through the assembly, but I can’t get the assembly to come out. Is there another bolt etc. that I’m missing? I don’t want to force the issue.
Are you sure you have to remove the headlight assembly? Consult the owner’s manual for information about bulb replacement.
owners manual does not give any information as to replacement, just what bulbs to use.
What year? There are 3 different models, and they are all different in how you replace the bulb.
It’s the Grand Cherokee Ltd. I found another site that has enlightened me. Thanks
