I recently purchased a used 2001 Isuzu Rodeo Sport. The back cover zipper or back park of the soft top can not be zipped up all the way. Is a new soft top cover from a parts store the only solution or would it be possible to find another alternative to seal the back off?
A good automotive upholstery shop or a place that does convertible tops should be able to replace the zipper.
Take a candle and rub it along the teeth of the zipper. Then try using the zipper.
The top material shrinks over time, if the top won’t close replacement tops are available;
You might also look for places that do boat covers.
Tester suggested exactly what I was going to suggest. Try a candle.
Years ago, when all zippers were metal, stores used to sell “zipper wax”. But, alas, it’s a thing of the past. I use candles now.
The other thing you might want to do is take a very close look at the spot the zipper hangs up at. There may be a loose thread hanging it up.
