Intermittent Car Stereo
I have a Ford Mondeo (UK) and recently the car stereo started turning itself off at random intervals. I cant work out why? I could be stationery in my car with the engine running and it will turn off intermittently, I could be stationery without the engine running and it will turn off intermittently, I could be driving on a motorway or on a local road (at speed or slow) and it will turn off intermittently, I could be indicating , have my wipers one heated windows, bluetooth or none of them running and it will turn off intermittently?? Completely at a loss as there is no common denominator. My first thought was the radio was worn out (7 years old) so I replaced it only for my new head unit to do the same thing. Obviously I have an electrical fault but I cant find it???
Any advice would be appreciated.
Thanks
Simon
Here is what you need.
http://www.proteckmachinery.com/stats.php?p=2008-ford-focus-stereo-wiring-diagram
Thanks for that, I’ll try and have look at the weekend!
Have a look at this…
Hope this helps you.
http://www.carpartkings.com/contitech-heat-exchanger-to-pipe-hvac-heater-hose-chh0147r.html
