So, is the 3.2 Ltr engine from Mopar an interference engine or not? I’ve heard from both camps, one saying that if the timing belt lets loose while the engine is running, it’s toast, and the other folks saying “It just won’t run anymore, but can be easily fixed.” So, what’s the scoop from engineering?
According to the Allpar page the 2.7, 3.2, and 3.5 engines all use a timing chain.
http://www.allpar.com/mopar/new6.html
Ed B.
May be a timing chain…but it still could be a Interference engine.
edb1961
mrmainsqueeze
SECOND OPINION HERE
Mr. Main Squeeze doesn’t give make, year, model, etc.
However, I am putting the second timing belt on my 97 Dodge Intrepid 3.5 !
I know my wife’s 99 Intrepid 2.7 has a chain.
I have factory service manuals for them both.
The 99’s manual has a “CAUTION: The 3.2/3.5L are not freewheeling engines, therefore care should be taken not to rotate the camshafts or crankshaft with the timing belt removed.”
Guess what rotates when mother nature removes your timing belt?
Also, WARNING! According to the Gates Timing belts site, the 3.2 I looked up has a belt and it is an INTERFERENCE engine.
Gates supplies a lot of automtive belts to the automobile world.
Check out page on the link below. Find the part about interference engines and put your particular info in.
http://www.gates.com/brochure.cfm?brochure=2256&location_id=3487&go=SearchGatesPopular
mrmainsqueeze,
If you would like more help with this determination then please post make, model, miles, and year of vehicle.
mrmainsqueeze,
We would like hearing from you again. Did we help? Feedback helps us with our advice.
