where is the inline fus on the alternator for a 93 toyota paseo?
The fuse is in the main fuse panel under the hood. Refer to the owner’s manual for location. There should be a fuse guide on the inside of the fuse panel to tell you which large fuse is the alternator fuse, typically the one labeled ALT.
