Hi all,
*I am not an auto expert so apologies for lack of knowledge or terms
1997 Chevrolet Cavalier
My fuel injectors were leaking and I wound up replacing all 4 of them at a mechanic. The only symptom I had of this was smelling gasoline when my AC or Heater was turned on.
The very night when my car went home, I developed a sudden brand new random problem.
Previous to the fuel injector change - when I try to turn my car on - I just turn the key and the engine cranks for a second or two then “turns” on. Now, when I try to turn the car on, the engine just cranks like 4 or 5 seconds and then barely…barely comes on. Like, the engine doesn’t sound like it turns on, but when I stop cranking for the 4 or 5 seconds - somehow the car awkwardly / weakly comes on. If I only crank the engine for like 2 seconds, it will not turn on at all. It needs like 5 seconds to barely turn on.
However, if I try to crank the engine for 2 seconds and it doesn’t turn on, then immediately when I try to turn the engine on again, it goes on like normal. ADDITIONALLY, if I just stopped the car like 10 or 15 minutes ago and I try to turn the engine on again, it goes on like normal as well.
If I try to crank the engine for like a split second and then try to turn on the second time though, it will not work. It needs like a second or two for the first crank.
ADDITIONALLY (more additionallies), my car when I try to accelerate now sounds like its struggling to accelerate.
ADDITIONALLY, if I try to crank the car and I just tap the gas pedal, the car starts extremely extremely quickly.
This all started the night I got all 4 of my fuel injectors changed. The mechanic doesn’t seem to know why this is happening. He gave me a new fuel filter and it did not do anything to fix the situation.
Any ideas what can be happening?
