NO VACCUM LEAKS.CHANGED IDLE AIR CONTROL VAVLE.DEALER TO MUCH MONEY.PLEASE HELP
Can’t help, no info, no answer.
I think that’s
CAN’T HELP.NO INFO.NO ANSWER.
How do you know there are no vacuum leaks? Did you put a gauge on it? Do a smoke test? Check the IAC valve wiring.
Put a fuel pressure gauge on it as well.
Model, Year, Milage would help.
Quit screaming, we are not deaf!
I had it check for vaccum n smoke test. check the wiring.
