Hyundai Genesis cranks but won't start
2010 Hyundai Coupe 2.0 turbo. replaced fuel pump and relay . cranks but wont start, plugs fire and have fuel pressure to fuel rail.HELP
  1. how much fuel pressure do you have?
  2. how did you test that the plugs are firing?
  3. the injectors are pulsed via a signal from the crankshaft position sensor. Did you check for pulses with a noid light?
