Hub Caps
Recently two of the hubcaps on my 1999 Buick Le Sabre have been coming loose after about 100 miles of driving. Does anyone know how to keep them secure? I don’t want to buy aftermarket hubcaps. The wheels are balanced and the rims are in good condition, as are the tires.
If you remove the hub caps, you’ll see a spring wire that secures the hub caps to the wheels.
Take a pair of pliers, and carefully bend the spring wires towards the outside of the hub caps so they grip the wheel tighter.
