How to replace rear brake pads on Ford F 250
How do I replace the rear brake pads on an f 250
If you have to come here to ask, you might want to reconsider having a professional do the job. Going is optional, stopping is not.
What’s the model year?
I’d recommend a Haynes manual for the vehicle, if available. There is lots of advice on line and youtube, but unless you have the fundamentals like in a Haynes, it’s hard to separate the good from the worthless and even dangerous.
Here is a good video that will help you do the job right.
Buying a Haynes, or Chilton manual will give you all the specifics.
Yosemite
Look for a Utube video on doing a brake job on your year F250.
Thanks man, did, and this old carpenter probably can pull it off
