The horn on my 2002 Jeep Grand Cherokee [34k miles] suddenly stopped working. Everything else works fine. Any thoughts? Anyone know where the horn is?
Check the fuse box. The horn is under the hood somewhere, usually behind the grill. If the fuse is OK it could be a bad horn relay, a loose connection, or a bad horn. A blown fuse is the most likely cause.
