I put synthetic blend in my used 09 focus like about 2 weeks ago. 123k miles. No maintenance history. Driving it daily. The oil on the dipstick still looks clean but from where you put oil in, it looks like there might be sludge build up. Should I go ahead and put a high milage oil with its additives or just keep using synthetic blend? Or upgrade to a non hm full synthetic oil?
Just use the type of oil recommeded in the Owner’s Manual, and focus on very frequent oil changes in an effort to get some of the sludge out. Ask your mechanic to remove the valve cover in order to determine the extent of the sludging, and see if he recommends flushing the engine to get some sludge out.
What does “HM” stand for?
High milage. Theres synthetic blend hm oil and full synthetic hm oil. Detergents and additives added to the oil.
If i upgrade, im thinking of going with supertech full synthetic. Really cheap but I wish they had a synthetic blend. They only have conventional.
High mileage oils contain additives designed to reduce oil leakage by softening/swelling the seals. To the best of my knowledge, they don’t have a higher detergent content.
When high mileage oil swells the rubber seals, that means it’s starting to dissolve them. It will work for a while, but if you plan to keep this car for a few years, I would just use regular mineral oil and change at least as often as Ford recommends for severe service.
The OP might want to consider using something like this product a few minutes before his next oil change. Please be sure to read all of the info on the following website and on the product’s packaging, and to follow the directions precisely.
https://www.valvolineglobal.com/en-ksa/engine-flush-what-is-it/
It is cold. Happens in winter. That does lead to some scummy stuff on oil fill cap. Could be frequent short trips in cold weather.
You contradict your self, did you mean to say supertech is only available as synthetic, rather than blend?
Full synthetic will not hurt your engine.
What Is High Mileage Oil?
For drivers with worn-out vehicles, high mileage oil can be a game changer. But what exactly is high-mileage motor oil, and how does it benefit your aging engine? Let’s dive into the details.
Oil for high mileage is a type of motor oil made for older cars—typically those with over 75,000 miles. It has extra ingredients that help keep aging engines running smoothly, such as:
- Seal Conditioners: These chemicals revitalize and maintain the elasticity of engine seals, resulting in fewer leaks.
- Extra Detergents: These additives help keep the engine clean by preventing sludge and deposits from accumulating.
- Anti-wear Agents: These compounds provide additional protection against wear, which can be more pronounced in older engines.
- Viscosity Modifiers: These aid in maintaining correct oil thickness at different temperatures, resulting in better lubrication.
- Friction Modifiers: These additives minimize friction between moving parts, which increases engine efficiency and performance.
High mileage oil exemplifies breakthroughs in automotive science. It provides a personalized solution for individuals looking to conserve and safeguard their car assets.
I’m confused. Is the oil clean or are you seeing sludge? I seriously doubt that you could see any sludge from the dipstick. At the very least you’d have to pull a valve cover or drop the oil pan.
I’ve never used high mileage oil before. Even on vehicles with well over 300k miles. Never an issue. Some people swear by it and have seen great results. It won’t hurt. But what’s considered high mileage?
That’s not necessarily an indication of sludge. That could be the engine not getting up to proper temps and water is mixing with oil. I see it on many cars.
No maintenance history? Did you just buy the car? Anyway, a little sludge build up under the cap is normal. Just wipe it off and carry on.
If you can take a flashlight and look down into the oil fill area and see a lot of sludge, then the no maintenance history is an indication that very little maintenance was done.
If the sludge is brownish in color, then some moisture is getting into the engine. This could be nothing or could be a sign of real trouble coming. Mostly it is just the seal on the cap is dirty and allowing some moisture to get into the area, cleaning the seal will solve the problem. Worst case is a blown head gasket or worn out rings. If you have a blown head gasket, you would notice some coolant loss, if you have worn out rings, then you would see significant oil loss, like a quart every 500 miles or less.
Moisture can also get in through the PVC system, usually an easy cheap fix.
If you want a synthetic blend, buy 4 quarts of dino oil and one synthetic. To my mind, semi synthetic has no purpose. They don’t tell you the percentage of synthetic and today if you are buying the oil yourself, synthetic is pretty cheap in a 5 qt jug.
I run HM oil on all my vehicles starting at 75K miles, never had an issue, also recommend HM to all my customers with over 75K miles on the engine, in 17 years with the same company, never had an issue through out the company due to using HM oils, nor since I retired in 2021 (I keep in touch lol)…
Now HM oil is not a repair, so if seal blown out or gasket leaking bad, replace it…
I suggest checking the crankcase vent system THOROUGHLY.
Bottom line: use the grade and type (conventional, blend, or synthetic) oil specified in the manual. It’s that simple. If OP wants to be ‘nice’ to the engine, no harm in using synthetic and/or HM of the proper grade even if it’s not specified. I’d use synthetic if cold weather was involved.
