Everything I’ve found on replacing the crank position sensor on my 2002 5.8l Chrysler town & country says its on the bellhousing but its not there! Any suggestions?
Maybe that wrong engine size is the problem.
3.8l sorry
Look on the firewall side of the engine block about 8 inches above the oil drain plug. Older 3.3, 3.8L were on the bell housing but it has been moved to the engine block.
