Heating & AC fan not working
front fan not working, rear fan works fine
Tap on the front fan motor with a screwdriver handle and see if the motor comes on. If so, the motor is defective. If not, use a test light and see if there is power at the motor. If there is, the motor is defective. If there is no voltage, check for a blown fuse.
