Both my headlights and my map lights didn’t turn on/seemed not to be working when I was driving home tonight, so I couldn’t see and had to use my high beams. I’m a grad student who doesn’t make much money, but I’m worried that both lights being out at the same time indicates a larger problem. Is there any reason why both would be out simultaneously?
I should also mention the green light that shows up on my dash when the headlights are on also wasn’t showing up – only the blue high beam icon when I switched to high beams.
I’d search the owners manual. There are more settings than ever for simple things like headlights on/off. You may have inadvertently changed a setting.
The glove box light works. I won’t be able to have someone look at it until Thursday night, so I’ll tell my friend to check the fuse/fusible link. Thanks.
