Headlight repair
I have a 2003 Hyundai Sonata. My problem is my car has high beams but no low beam. Wath is the problem?
See if your fog lights work. If they do, the low beam bulbs are probably burned out.
If the fog lihts dont work check the low beam fuse & relay under the hood & passenger compartment fuse 10.
See the fuse list & diagram in your owners manual
Possibilities include:
Bulbs
Fuse
Relay
Wiring
Switch
I suggest you start looking in about the order above.
Bulbs, dimmer switch…Headlights usually are protected by automatic resetting circuit breakers, not fuses…
