Head Lights out Bright lights ok
2001 jeep cherokee limited 4 . switched to brights and when I turned the off headlights were out. dashboard lights , running lights and brake lights ok, both fuse boxes ok. whats next
Check the low beam relay in the fuse box under the hood.
True story…
Several years ago I had to use my wife’s car in the evening for a short trip. I noticed as it got darker that the low beams weren’t all that great. I switched to high beam and they weren’t as bright as I had expected they’d be, either.
I stopped the car with low beams on and got out to look at them. One side was out because a low beam filament had burned away. I threw on the high beams and took a look. The high beam on the opposite side was out because the filament had fried. :face_with_hand_over_mouth:
Long story, short version, had my wife kept driving she eventually would have had no low beams and/or no high beams as another light burned out. She was one filament short of total darkness.
Two new bulbs fixed it. Wow! I could see! Not sure if it helped my wife, ha, ha… :smirk:
Unless one checks frequently or drives where it’s dark (and is observant) this is what can happen.
So, if a temporary relay swap (with another of the same part number in a non-critical location in the fuse/relay box) doesn’t do it then examine the bulbs carefully.
CSA
:palm_tree::sunglasses::palm_tree:
That’s not nice to say about your wife.:joy:
Yosemite
“She was one filament short of total darkness.”
It’s Okay. She’s a Trophy :trophy: Wife!
