I have a hard start problem…starts and dies…diagnosted as anti-theft problem…can wait 10 minutes and car may (may not) start…tech said common to this model is a bad cluster…sent it to be tested and repaired…they tested it said it was good…reinstalled it also checked ignition passock voltage…VTD…reads 2.3volts always…installed an ignition by pass kit…still has same problem…only thing different from the begining of the problem is now anti theft icon on dash lights up, gear position selector shows only park and car rarely stays running…apparently the anti-theft system is working as it is intended but what is telling it to shut down the fuel to the engine.??? HELP!! HELP!!
Related topics
| 97 Buick Skylark | 3 | 825 | January 31, 2011 | |
| 1997 buick skylark starting problem | 1 | 545 | November 18, 2008 | |
| Anti theft intermittent problem 97 buick skylark | 6 | 4087 | February 28, 2008 | |
| Bypassing the theft system | 3 | 812 | November 15, 2010 | |
| Resettng anti-theft device after replacing instrument cluster | 4 | 1523 | September 9, 2013 |
