Hi,The problem I’am having with my 2003 grand am is when i turn left it makes a clunking noise.It only does this noise when the temperature outside is 50 degrees and higher.Had everything checked and nobody can find anything wrong.any suggestions would be appreciated.
I’m gonna suggest a possible engine or tranny mount. Most check thing slike strut mounts, but not everyone checks engine mounts.
Understand that this is just a guess. Things this unspecific can be impossible to guess at from a distance.
Is it a single clunk or could it be described as a clicking noise? It it is repeating, I suggest having the CV joints checked.
you have the plastic hub caps right?
remove them.
see if that makes a difference.
