I have a loud clunking noise when I turn left only. I took it 20 times to mechanics and they can’t figure out the problem. I have spent 2,000 dollars on work that never fixes the problem. New struts,control arm bushings. Seems to be weather related. Doesn’t make the noise below 30 degrees. Can also feel the clunk when turning. I would appreciate any suggestions. Thanks
Classic CV joint.
i have the exact same problem, with every turn it makes me cringe ive been looking online and some say its the cv joint or axle, i dont know if youve had these parts replaced if you did and still no fix that would save me a lot of money
