Got towed and now can't start up
I’ve had my 97 Chevy K2500 for almost 2 months.
This morning I needed a tow, the ujoint in my rear drive shaft snowballed. I was able to start the truck no problem as I waited for help.
Got towed by a wrecker (the kind where they wench you up so your wheels are all off the ground).
He unloaded the truck at my house.
Now sitting in it calling for parts, I realize:
The truck won’t start, nothing works, no ignition and most peculiar:
There is a noise coming from around the steering column/ with hood open it seems to come from around where cruise control box sits.
The noise sounds like when you wind up a jewelry box but instead of it playing the song it just winds.
If I hit the brake pedal or flip the light switch it stops.
with the light not coming on of course. But it comes back after a few seconds!
Battery still connected.
What the … happened? I’m worse off now than before the tow.
My truck is manual transmission. The wrecker driver did all hat with putting in neutral etc as far as I know. He just asked for key then went about putting it on the platform.
I called insurance that dispatched the wrecker to let them know.
I know what to do about my drive shaft but what do I do about this strange noise and starting issue?
Thank you in advance!
He left the ignition on and now the battery is discharged. Recharge the battery.
I’ll try that. Thank you!
