The suggestion to use a slightly smaller socket has worked well for me in the past. Try a 13mm and hammer it on if you have to. You could also try a 1/2 inch socket as that converts to 12.7 mm. I would suggest using impact sockets as well.
cwatkin
21
Related topics
| Using a Torch | 59 | 4066 | November 25, 2012 | |
| HELP. Stripped Tire Lug Nut | 16 | 3876 | October 25, 2011 | |
| How to remove stripped torx bolt? | 34 | 25886 | May 14, 2023 | |
| 91 LeSabre strut nut | 10 | 1016 | June 13, 2010 | |
| Ideas to remove nut from bolt, clearance problem | 35 | 24862 | September 3, 2016 |
