Fuse location 1989 Camry
I am trying to find the fuse for the windshield washer pump. The wipers work fine, but the washer doesn’t do anything. I did confirm that the hoses are clear.
The washer pump is on the same fuse as the wipers. So if the wipers work there’s nothing wrong with the fuse. More than likey the washer pump requires replacing.
