Nice coffee table
huh?
I jumped the gun a little.
I like it… the wife, not so much.
I wonder how you get the wine bottles out without having to move the glass top.
The bad news is that wine shouldn’t be stored this way if it’s bottled with an actual cork because the cork dries out and lets air in, wrecking the wine.
The good news is that the wine means you have a coffee table which runs on alcohol and is therefore a drag racing table.
It’s not my style. Engines don’t belong in the living room. They belong in the kitchen.
The wine bottles are neck up so that you can tell what they are. In practice, the bottles would be stored neck down.
I can see that. You’d need the Incredible Hulk to help move it to a differnent spot though.
An engine that clean is downright scary.
I can see that. You'd need the Incredible Hulk to help move it to a differnent spot though.
An aluminum block with the heads off and the crank out is surprisingly light. I can easily pick up and carry an aluminum four cylinder block minus head, crank, and oil pan.
