My toyota camry’s fuel tank flap and knob are jammed. The lever to open the flap stopped working, so I used a screw driver to pry open the flap. But now the fuel tank knob is jammed.
Any ideas? how to open the jammed fuel tank knob?
What is a fuel tank knob? Are you talking about the gas cap? The fuel door problem is common with Camry’s and is the result of a broken spring in the door hinge. The part is abou $5, available at Toyota dealers, and is easily installed by yourself in 1 minute.
