how do i replace a fuel filter in a 1999 grand prix GTP, i am mechanically inclined, but not an expert
Get a Haynes manual. For less than $20, it will have all the info you need to do the simple to complex maintenance on your car. Available at most auto parts stores.
my 97 rav4 haynes says to take back seat out to get to fuel pump wire to unhook.
Heard of a trick, find fuse for pump and start it then unhook fuse till it dies this takes pressure out of fuel line, if you do not it will spray all over
