will car seat from a 2006 crown victoria
 police interceptor interchange with a 2000 crown victoria police interceptot
There are levels. The first thing is, will the replacement seat bolt up into your car. This is pretty easily checked and the answer is probably yes. You need to see if the four bolts holding your current seat match up to the bolt holes on the 2000 seat. If they do, and all you want is the new seat and none of the gadgets, you are all set. If you have heated seats and full motion powerseats, I’d guess that the two seats are not interchangable for all functions, if any of them.
Don’t forget about the SRS sensors inside the seat.
