i have a 1994 ford escort where are the coolent fan relays located.
Under the hood in a black plastic box.
The relay is located under the air filter box. Unclip the top of the air filter box and remove the filter. Remove the two bolts and one nut that hold the box to the bracket, and remove the box. You may have to unplug the mass air flow sensor connector to remove the air filter box.
thanks a lot
