I have a 2001 Dodge Caravan, I was having problems with the turn signals and now the speedometer needle has moved all the way around and is now behind the stop pin. How do I reset my speedometer?
I guess it is analog. Remove the dash cluster, see if you can get at the arm? If all one assembly, may have to get new cluster. I’d have to look at it.
