When im driving my truck down the road all the power cuts off then comes back on, don’t know what it is please help?
Check the battery and ground connections. It could be a bad ignition key or main relay, but I would start with the basics.
I think that Mitt Romney had electoral problems last Fall, but what you might have are electrical problems. Sorry, couldn’t help myself. Seriously, start at the battery and start cleaning contacts, first battery posts, then battery cables, then cable to ground, then fuse block, look at your main fuse and other fuses for corrosion, and try to eliminate things. Do you drive the truck much? I had an old pickup which I only drove once or twice a month, sometimes less, and I had issues like this, fixed it every time. Rocketman
