Ecu or c;udter bungle?
Here’s the history…
Bought the B150 a year ago. Repaired the front brakes
changed the oil and filter that’s all.
Ran fine, including a 4,000 mile round trip to Canada,
until now.
The brake light in the cluster has always been on but does
not register in the code reader.
Check engine light has never come on.
Speedometer does not start indicating until 35 mph.
That started 2months ago
changed the oil 2 weeks ago
Engine was stalling at lights and in turns.
For the past 2 months. Which is when I got back from trip
to Canada.
Added water remover and octane boost.
Ran better for about 2 weeks.
starts right up when cold
good oil psi 40 when idle 60-80 when running
died on the road, at dusk on way back from taking saiboat
to marina from which I sail. Jimmy Buffet’s old hang-out.
It’s where you an get that cheeseburger-in-paradise.
Pirates Cove.
Repaired engine by replacing rotor, dist.cap,
spark plugs and wires, and coil.
drove 12 miles with no problems to do laundry (2 hrs)
drove 3 miles,motors dies with a cop following, OhBoy!
got out checked the vitals,nothing out-of-the-ordinary
added less that a quart of anti-freeze. After 15 minutes
of just looking around, got in started engine and drove to
grocery store (15 min. in store) than drove home.
Engine died every time I slowed down at stop lights and
stop signs. 2 times. One time the oil pressure gauge went
to zero pressure and engine was still running. The code
reader read “primary and secondary ignition circuit”
before and after I replaced all the parts.
By the way the cop slowed down to smirk, but keep going!
It would be nice to know the vintage of the Dodge van?
90% of your blather has NOTHING to do with your problem…WHAT, exactly IS your problem??
Hard to read your
post.
Too many inappropriate
paragraph breaks to make
heads or tails of
your woes. But here is the
best advise I can make.
Brake light is not set with a trouble code, so code reader doesn’t have anything to read there. Brake light is on due to either 1) low brake fluid, 2) parking brake not fully released, 3) problem with dual piston master cylinder balance, or 4) problem with sensors for each of these functions.
The code reader shoould give you a code, like P0131. Post these codes for a better interpretation. Obviously the problem was not in the parts you replaced, since the DTC is still set and CEL is still on. Post the code and we can help you figure this out better.
Also, I hope you changed the oil more than once in the year you owned it. If not, that may explain the low oil pressure you noticed.
Year and mileage would also help.
1998 Dodge b1500 ramvan. Oil changed twice in a year. I was told that they did a tune up. Apparantly a sales trick. The problem is that it dies for not reason at speed. The plugs, rotor and dist. cap were in bad shape but they are now new. I now suspect the crankshaft position sensor, throttle position sensor, nuetral switch, the PCM (computer)or the cluster. I am not in the position to replace all these parts. I anyone knows of a way to get a wiring schmetic I could make an eduated guess at which part to try next instead of replacing al of them.
Stop writing
e.
c.
cummings
poetry.
This is a group of folks who fix cars and I HATE e. c. cummings. Just too hard to make sense of. So if you have a code post the code number here. The brake light means you did not adjust the brakes correctly or you lost a return spring to pull the pedal back to the top where it will turn out the light. You need a mechanic. If you have not figured out that then please write poetry and never fix cars.
